建筑时空 首页 建筑作品 交通建筑 查看内容
福厦铁路厦门北站
2017-2-17 12:06| 发布者: 唐文胜| 查看: 4672| 评论: 0 |原作者: 唐文胜
简介:This project is an important junctionhub on the Fu-Xia high-speed railway line from Fuzhou to Xiamen and the largestcomprehensive transportation hub in the southeast coastal area of China integratingt ...
Architect: TANG Wensheng
Tel:+86-27-87336993                   Fax:+86-027-87337156   E-mail:    519676506@qq.com
TeamMember:
WAN Zhiying, HU Haiou ,WAN  Qian, WU Zhengshan.
Address: Central-South Architectural Design Institute Co., Ltd.,  No. 10 Zhongnan Er Road, Wuhan, HubeiProvince, P.R.China  (430071)
Client/Owner: The southeast coastalrailway(Fujian)  co., LTD
Consultants:
(e.g. Engineer,Sociologist, Demographer, Economist, etc.)
Structural Engineer: LI Ting,XU Min,XIONG Shen,WAN Haiyang.
Mechanical Engineer: HONGYing,ZHANG Xin,TU Zhengchun,XU Hong.
Lighting engineers: ZHAO Fang
Economist: Economist:XU Wenbo
Landscapedesign: TANGWensheng,ZHAO Xin,HU Haiou
Interior Design: TANGWensheng,YITIANDesign
Steel structure: Zhe JiangSoutheast Space Frame Co., Ltd.
Glass curtainwall: Shenzhen ShenZhuangZong DecorationCo., Ltd.
Contractor:China railwayconstruction group co., LTD
This project is an important junctionhub on the Fu-Xia high-speed railway line from Fuzhou to Xiamen and the largestcomprehensive transportation hub in the southeast coastal area of China integratingthe functions of railways, interstate highways and urban roads, long-distance coach,rail transport transfer and commercial services as a whole. (The annual averagepassenger number has reached 11 million.)
As a landmark of Xiamen (a big city in China), the railway station  building is constructed with a two-way roof spanof 132 meters by 220 meters,which is  thelongest single span length in the world that has been built.
The utility of lightweight and highlystretchy Megastructure, which is the large span steel structure using spatialtruss supporting cured-surface space frame, ingeniously reflects the“swallow-tail ridge” imagery of local residence in South Fujian and theinheritance of regional culture. The overall image fully presents the urbanspirit and features of Xiamen.
Close integration and seamlessconnection with the urban transportation make the passenger transfer easily andconveniently.
Professional and high-efficient plansrepresent characteristics of railway station in Chinese metropolis.
The large-span column-free space isclear and readable, offering a through view and strong visual guidance. Thepassengers inside the station have full understand and clear idea and controlof their route.
By using the “swallow-tail ridge” oflocal residence in South Fujian, the architectural form not only reflects thelocal culture features, but also fully reflects the true and reasonablestructural load bearing at the same time. A light roof reflecting the aestheticof structural mechanics is created by using the spatial-truss-supportedcurved-surface space frame structure system. The main roof span at 132 metersby 220 meters is the longest single span in the world among those railwaystations already constructed.
Energy-saving concept roots in thewhole process of design. The most advanced natural light system, sun
shading system, ventilation system andthermal pressure driven natural ventilation system  are applied to the new railway station.
Uniqueroofing system
The megastructure system that isspatial-struss supporting curved-surface frame is a perfect combination of thearchitecture imagery and structure, ingeniously reflecting the features of the “swallow-tailridge”of local residence in South Fujian. Four large-span spatial steel truss arrayalong the roof ridge with both ends of the steel trusses supported on the giantA-shape steel reinforced concreted tower columns. These together constitute thegiant composite frame and form the main load-bearing system and double lateralforce resistant system of the roof.
The roof space frameconsisting of two-way intersection trusses with unequal heights (an overrunnew-type complex spatial grid structure): the lower chord joint of the orthogonaltrusses with unequal heights is the first application in China. (A nationalpatent has been approved.)
The station building’s two-way roof spanis 132 meters by 220 meters. The architects have fully considered the real andreasonable structural load bearing during the architectural form creation. Byworking with the structural engineers, architects created the advancedstructure technologies like the structure system of giant A-shape tower column,giant composite frame and roof space frame consisting of two-way intersectiontrusses with unequal heights. With the roof structure steel consumption indexcontrolled at 99kg/m2, it becomes a railway station building with the longestsingle span in the world among those already constructed with very economicalindexes. It has been awarded with the Outstanding Structure Award of 2015 IABSE(International Association for Bridge and Structural Engineering).
Sustainable development of the wholesystem throughout the whole life cycle
The step-down slope roof that is highin the middle and low on all sides and the electrically operated skylights areadopted. The good natural ventilation is realized by using the thermal pressureventilation principle and the uniform daylighting illuminance is achieved byarranging the skylights dispersedly.
