建筑时空 首页 建筑论文 建筑基础论文 查看内容
论后增加剪力墙在工程中的施工方法
2013-12-14 10:02| 发布者: ccbuild| 查看: 379| 评论: 0
摘要: 摘要:施工组织设计是工程施工的指导和前瞻,明确的工程管理目标,科学可行的管理及总体部署,先进的技术施工方法,完备周到的准备计划,详细严谨的质量保证措施,稳妥全面的安全文明措施,是衡量一个施组是否合理的 ...
摘要:施工组织设计是工程施工的指导和前瞻,明确的工程管理目标,科学可行的管理及总体部署,先进的技术施工方法,完备周到的准备计划,详细严谨的质量保证措施,稳妥全面的安全文明措施,是衡量一个施组是否合理的标准。本设计正是遵循这个标准对一个综合服务楼后增剪力墙工程从准备到施工的整体考虑及阐述。施工进度计划的编制合理性和可操控性,是按预期要求顺利完工前提;正是本着以上要求,对某综合服务楼工程的后增剪力墙施工组织设计进行编制。
关键词:施工组织;施工方案;施工技术措施 中图分类号: tq639.2 文献标识码: a 文章编号: abstract the construction organization design is the whole leading of engineering and forward-looking, the explicit engineeringmanagement target, viable management and total deployments of science, the forerunner’stechnique construction method, complete and thoughtful preparation plan, detailed and careful quality control measure, steady completely safe civilization measure, is measure a shi zu3 whether the standard of the reasonable.this design follows this standard exactly to a comprehensive servicebuilding engineering from the whole consideration that prepare to start construction and elaborate, and as to it’s the medium applied new technique and the solution of the quantity common failing that meet usually in shi gong did the detailed introduction.planned establishment rationality of the construction degree of progress and can operate sex, is an engineering to press expectation to request to finish construction the premise smoothly;start construction on the scene the total plane chart is various to anticipate, the machine, homework the spot and road, water, electricity of alignment also started construction to provide the guarantee with safe civilization for the spot.be in the light of exactly to have already requested up, carry on according to the construction organization toward the some comprehensive service building engineering design learn to draw up as follows. keyword:explicit, forerunner, complete and thoughtful, detailed and careful and steady overall 一、 编制依据 1、 结施施工图纸 2、 建筑施工图纸施工图纸 3、 《工程测量规范》(gb50026-2006) 4、 《建筑安装工程安全技术规程》 5、 建筑施工安全检查标准(jgj59-99) 6、 建筑施工高处作业安全技术规程(jgj80-91) 7、 建筑机械使用安全技术规程(jgj33-2001) 8、 施工现场临时用电安全技术规程(jgj46-2005) 9、 建筑工程施工现场供电安全规范(gb50194-93) 10、 《建筑结构荷载规范》。 二、 工程概况 1、工程名称:哈尔滨音乐厅 2、工程地址:哈尔滨市群力新区群力大道与景江东路交汇处 3、建设单位:哈尔滨群力新区开发建设管理办公室 4、设计单位:上海现代建筑设计研究院 5、项目管理管理公司:北京远东工程项目管理有限公司 6、监理公司:浙江江南工程管理股份有限公司 7、施工单位:黑龙江省建工集团有限责任公司 三、工程简介 哈尔滨音乐厅工程位于群力新区群力大道与景江东路交口,东临丁香公园,北临松花江浅滩,西临某高层建筑,南与音乐谷相望。本工程地下一层地上四层,地下为车库及设备间,一层为办公区,二至四层为两个音乐厅。屋面为钢桁架结构,外墙为玻璃幕墙,屋面为陶土板。 四、施工条件 1、根据设计要求在已经施工完的(地下室、一层、二层)楼层内增加剪力墙,其主要目的是考虑音乐厅的隔声要求。 2、由于隔声剪力墙是后增加的,地下室、一层大部分墙体已经砌筑完成,施工时需将已经砌筑完成的部分墙体破拆、外运。需要拆除的部位有,st#02右侧墙体、ev#02旁边管井下侧墙体、st#05上侧墙体、st#05与右侧弱电井连接的墙体,共计20.5m3陶粒墙体。将拆除的碎陶粒用运土车运至15km外的土场。 五、工期目标 2012年8月7日~2012年8月31日 六、施工重点 1、按照设计图纸,剪力墙钢筋采用植筋的方式与原有的结构连接。 2、钢筋绑扎过程要严格控制钢筋的搭接长度和锚固长度。 3、支模时要严格控制墙体的平整度、垂直度及模板的牢固性,防止出现涨模现象。 4、由于原结构已经施工完成,剪力墙的砼浇难度极大,为了使砼浇筑密实,采用插入式振捣棒和平板式振捣棒共同振捣。 七、施工准备 1、15㎜厚多层板500张(1220㎜×2440)。 2、50㎜×80㎜木方7000根。 3、脚手管5000根(6m/根)。十字扣件5000个 4、ф14对拉螺栓、大雁、小雁6000套。 5、ф15穿墙管(pvc)1000m. 6、钢筋60t. 7、c30砼1000m3 8、插入式振捣棒6台,平板式振捣器10台。 9、电钻6台(植筋用),植筋胶1t。 八、施工方法及技术措施 1、钢筋施工 1)植筋 在植筋前先在需要植筋的部位搭设双排脚手架,脚手架立杆间距1500㎜,水平杆间距1500㎜,小横杆间距1500㎜,水平杆和小平杆沿竖向设置三道。剪刀撑间距3m(每个独立架体不得少于两道剪刀撑)保证脚手架的稳定性。 植筋人员在架体上作业时要佩戴安全带,防止在植筋作业时滑落,造成人员伤亡事故。植筋时先用电钻(钻头要比植入钢筋直径大一个规格)在需要植筋的砼结构部位钻孔,钻孔深度为15d(d为钢筋直径),钻完一批孔后,用电吹风机将孔内的灰尘吹干净,然后用丙酮酸将所钻的孔清洗、风干后,把抹上植筋胶的钢筋塞入孔内,保证植入的钢筋长度15d(d为钢筋直径),孔内植筋胶必须填满。 所植的钢筋露在外面的长度为一个钢筋搭接长度(钢筋100%搭接)。 2)钢筋绑扎 按照图纸将需要绑扎的钢筋提前预制好,绑扎时利用植筋时搭设的脚手架先绑扎外侧钢筋,再绑扎内侧钢筋,然后将拉筋挂上,预制砼垫块垫好后,经验收合格后方可进行模板支设。 2、模板施工 1)模板的支设 模板施工前先在剪力墙的另外一侧也搭设双排脚手架,用ф14钢筋在剪力墙钢筋上焊上定位钢筋,控制钢筋保护层,定位钢筋间距600㎜,把预制好的模板沿两边的脚手架边运到需要支模的部位,穿入穿墙管和对拉螺栓进行加固。模板的次楞采用50㎜×80㎜木方间距150㎜,主楞采用两根脚手管,用大雁卡子与对拉螺栓拧紧,剪力墙模板一侧顶在梁底、另一层模板顶要比梁底低200㎜,在梁底200㎜处用模板做成斜口,斜口要比梁底高出100㎜,斜口通常设置,加固牢固,防止在砼浇筑时斜口脱落。 2)模板的拆除 砼浇筑完成后,待砼强度达到拆模时能保证砼的完整性时即可拆模,拆模顺序从上到下,拆除后将模板清理干净,码放整齐。 3、砼施工 砼施工前在剪力墙施工部位临近顶板处每隔1500㎜开一个200㎜×200㎜的方孔,保证原有钢筋部断开,方孔距离梁边不得小于100㎜,砼浇筑时从方孔将砼灌入剪力墙内,每浇筑300㎜振捣一次,插入式振捣棒从方孔插入,墙体上每隔2000㎜安装一台平板振捣器,在砼浇筑过程中,要派专人检查砼浇筑的是否密实,如发现有空洞处及时调整平板振捣器的位置,保证砼的密实度。砼浇筑完成后,观察顶部斜口处砼是否灌满,如未灌满,用人工翻锹将所缺的砼补上,振捣密实。砼浇筑完成后将楼板上开的方孔采用吊盒的方法,用高于原砼结构一个标号的膨胀砼浇筑密实,待砼达到拆模强度时将吊盒模板拆除。待剪力墙拆模后立即将斜口处的砼剔除。 九、附图1: 注:文章内所有公式及图表请用pdf形式查看。
